- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Benjamin Werner <benjamin.werner AT inria.fr>
- Cc: Li-Yang Tan <lytan AT artsci.wustl.edu>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] "existS" in Coq
- Date: Mon, 24 Oct 2005 07:52:25 +0200
Benjamin Werner wrote:
Hi,
Just do "Print existS". Actually it is the single constructor of SigS which is a pair of two objects of kind Set, but where the type of the second component depends upon the value of the first. There used to be some concrete syntax like {x:A|P} for it, but for some reason it seems switched off.Well, the notation {x:A & B} is an abreviation only for (sigS A (fun x:A => P)).
By the way, sigS types are presented in the book as "Nested Subset types" (9.1.2). The main example in
which this type is used is euclidean division with the type
{q:Z & {r:Z | a= b * q + r}}
Pierre
Anyway, since existS is a constructor, the first equality implies that A=Apply M N, which, I imagine is false.
So inversion H14 should make it.
Cheers,
Benjamin
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] "existS" in Coq, Li-Yang Tan
- Re: [Coq-Club] "existS" in Coq,
Benjamin Werner
- Re: [Coq-Club] "existS" in Coq, Pierre Casteran
- <Possible follow-ups>
Yves Bertot
- Re: [Coq-Club] "existS" in Coq, jean-francois . monin
Benjamin Werner
