- To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
- Cc: Li-Yang Tan <lytan AT artsci.wustl.edu>, stump AT cse.wustl.edu, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] "existS" in Coq
- Date: Mon, 24 Oct 2005 17:16:42 +0200
Hello,
I did not try to understand the example (too many complicated
formulas for my small head), I was just interested by a usage
of dependent rewrite.
However a vanilla "rewrite H3" instead of "dependent rewrite; simpl"
seems to do the job in that case.
JF
Yves Bertot a ecrit :
> Hello,
> I believe I understood your problem and found a solution.
> I would like to be able to brag that the answer was in the Coq'Art, but it
> requires a lot of ingenuity to find it. The pages to read are p.221 and
> p.248. On the first location, we discover that sigS terms are sometimes
> produced by injection. On the second page, we discover that inversion
> relies on injection.
> On page 221, a solution is also described to exploit the
> sigS terms: this solution is a tactic called "dependent rewrite". Here is
> my example, which I re-constructed from the partial information that
> you sent us (in the future, I beg you to give a full running example, so
> that we can be faster at devising a solution).
Inductive Pos : Set :=
empty : Pos | P0 : Pos -> Pos | P1 : Pos -> Pos.
Inductive q0_type : Set :=
Fun : q0_type -> q0_type -> q0_type | Base : q0_type.
Parameter Var : q0_type -> Set.
Inductive Trm : q0_type -> Set :=
Apply : forall a b, Trm (Fun b a) -> Trm a -> Trm b
| Lambda : forall a b, Var a -> Trm b -> Trm (Fun b a)
| Tvar : forall a, Var a -> Trm a.
Implicit Arguments Apply.
Implicit Arguments Lambda.
Implicit Arguments Var.
Inductive subtrm : forall a b, Trm a -> Trm b -> Pos -> Prop :=
subtrm_empty : forall a A, subtrm a a A A empty
| subtrm_apply0 :
forall a b t M N T p,
subtrm t (Fun b a) T M p ->
subtrm _ _ T (Apply M N) (P0 p)
| subtrm_apply1 :
subtrm t b T N p ->
subtrm _ a T (Apply M N) (P1 p)
| subtrm_lambda1 :
forall a b t x M T p,
subtrm t b T M p ->
subtrm t (Fun b a) T (Lambda x M) (P1 p).
Implicit Arguments subtrm.
Theorem the_problem :
forall s : q0_type,
forall t : q0_type,
forall M : Trm (Fun s t),
forall N : Trm t,
forall x0 : q0_type,
forall x1 : q0_type,
forall x2 : Var x0,
forall x3 : Trm x1,
subtrm (Lambda x2 x3)(Apply M N) empty
-> False.
Proof.
intros s t M N x0 x1 x2 x3 H; inversion H.
(* we get to the situation you did not like. *)
generalize H5.
rewrite H3.
discriminate.
Qed.
- [Coq-Club] "existS" in Coq, Li-Yang Tan
- Re: [Coq-Club] "existS" in Coq,
Benjamin Werner
- Re: [Coq-Club] "existS" in Coq, Pierre Casteran
- <Possible follow-ups>
Yves Bertot
- Re: [Coq-Club] "existS" in Coq, jean-francois . monin
Benjamin Werner
