- From: Andrew McCreight <andrew.mccreight AT yale.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] the intros tactic and eliminating existential quantifiers
- Date: Mon, 14 Nov 2005 09:38:01 -0500 (EST)
You can also use the same syntax as for conjunctions and disjunctions:
intros [x [y [z [n [A B]]]]].
-Andrew
On Sun, 13 Nov 2005, Pierre Casteran wrote:
> Selon Li-Yang Tan
> <lytan AT artsci.wustl.edu>:
> Hello,
> > Hello,
> > I have a simple question regarding the intro(s) tactic. Suppose I am
> > trying to prove the following implication,
> > P : Prop
> > Q : Prop
> > (P /\ (Q /\ R)) -> ((P /\ Q) /\ R)
> > I can pull to antecedent of the implication into my list of
> > hypotheses/assumptions by doing "intros [H1 [H2 H3]]". This is very
> > nice, since it saves me from having to do: "intro; elim H; intros; elim
> > H0; intros." I believe there is a similar trick for disjunctions, so if
> > the antecedent of my implication is say (P /\ (Q \/ R)), I can simply do
> > "intros [H1 [H2 | H3]]."
> > I am curious as to whether there is something similar if the antecedent
> > has a list of nested existential quantifiers.
> > For example, consider the following:
> > Theorem Fermat :
> > (exists x, exists y, exists z, exists n,
> > (n > 2) /\ (x^n + y^n = z^n)) -> False.
> > Is there any way I can introduce x, y, z, and n into my assumptions
> > *without* having to do the following?
> > intro.
> > elim H; intros.
> > elim H0; intros.
> > elim H1; intros.
> > elim H2; intros.
> Hi,
> You can do the following :
> intros (x,(y,(z,(n,(H,e))))).
> 1 subgoal
> x : Z
> y : Z
> z : Z
> n : Z
> H : n > 2
> e : x ^ n + y ^ n = z ^ n
> False
> The rest of the proof is left as an exercise.
> Best regards,
> Pierre
> > Bug reports: http://coq.inria.fr/bin/coq-bugs
> > Archives: http://pauillac.inria.fr/pipermail/coq-club
> > http://pauillac.inria.fr/bin/wilma/coq-club
> > Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
> Pierre Casteran
> http://www.labri.fr/Perso/~casteran/
> (+33) 540006931
> This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club] the intros tactic and eliminating existential quantifiers, Li-Yang Tan
- Re: [Coq-Club] the intros tactic and eliminating existential quantifiers,
Pierre Casteran
- Re: [Coq-Club] the intros tactic and eliminating existential quantifiers, Andrew McCreight
Pierre Casteran
