- From: "Akuma GnacGnac" <akumagnacgnac AT hotmail.com>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Re: Dependent Records and Streicher's Axiom
- Date: Thu, 17 Nov 2005 09:55:15 +0000
Hi Li-Yang,
I'm not sure I pointed out the problem but it seems this lemma can easily be proven via the f_equal function of type (forall (A B : Type) (f : A -> B) (x y : A), x = y -> f x = f y) when applied with the following instance of f :
fun (A : Set) (P : A -> Set) (e : sigS P) :=
match e with
| existS _ p => p end.
What I want to do here is using the fact that if two objects are equal, then applying any function to both objects will lead to the same result.
Then, we just have to apply a function that returns the last argument of the existS constructor.
But trying to declare such an instance of f leads to the following user error :
Inference of annotation not yet implemented in this case
So I guess the lemma is valid but can't be proven in Coq for the moment.
I hope I didn't say any big mistake, I hope I didn't point out the obvious and I hope I was of any help.
Hi All,
I am having trouble proving a seemingly intuitive fact about dependent
records:
Lemma projS2_eq :
forall (A : Set)(P : A -> Set)(x : A) (p1 p2 : P x),
existS P x p1 = existS P x p2 -> p1 = p2.
- [Coq-Club] Re: Dependent Records and Streicher's Axiom, Akuma GnacGnac
