coq-club - Re: [Coq-Club] Re: Dependent Records and Streicher's Axiom
chronological Thread
  • To: Akuma GnacGnac <akumagnacgnac AT hotmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Re: Dependent Records and Streicher's Axiom
  • Date: Thu, 17 Nov 2005 16:55:12 +0100
Akuma GnacGnac wrote:
Hi Li-Yang,
I'm not sure I pointed out the problem but it seems this lemma can easily be proven via the f_equal function of type (forall (A B : Type) (f : A -> B) (x y : A), x = y -> f x = f y) when applied with the following instance of f :
fun (A : Set) (P : A -> Set) (e : sigS P) :=
 match e with
| existS _ p => p end.
Unfortunately no. f_equal applies only to non-dependent functional types (A->B). Your function f can be defined but has type forall (e:sigS P), P (projS1 e), which is dependent. The generalization of f_equal to dependent function types is ill-typed (since f x and f y do not have *convertable* types).
Lemma projS2_eq is indeed independent in Coq's theory. However it is widely accepted as consistent. Standard library Eqdep contains an axiom equivalent to Streicher's K axiom, and several corollaries, such as the 2nd projection of dependent pairs.
But, going back to Li-Yang's problem, this axiom is not necessary since the domain of the first component (binary trees merely) has a decidable equality. In this case equality on 2nd projections holds. See Eqdep_dec for a proof.
Hope this helps,
Bruno Barras.
