- To: roconnor AT theorem.ca
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Making a List into a Tree with Structural Recursion
- Date: Fri, 16 Dec 2005 16:31:34 +0100
wrote:
On Fri, 16 Dec 2005What about this ?
wrote:
By complete binary tree I mean
<http://www.nist.gov/dads/HTML/completeBinaryTree.html>
but I think I would also be satified with a perfect binary tree
<http://www.nist.gov/dads/HTML/perfectBinaryTree.html>
Er, I don't mean a perfect binary tree, What a wanted to say is that all
the extra leaves don't need to be to the left. So long as all leaves are
at either depth n or depth n-1, I am happy.
Require Import List.
Parameter A : Set.
Parameter xx:A.
Inductive bint : Set :=
Node : bint -> bint -> bint
| Leaf : A -> bint.
Fixpoint step (l:list bint) : list bint :=
match l with
t1::t2::t3::nil => t1 :: Node t2 t3 :: nil
| t1::t2::l' => Node t1 t2 :: step l'
| _ => l
end.
Fixpoint iter (l:list bint) (n:nat) {struct n} : bint :=
match step l, n with
t :: nil, _ => t
| nil, _ => Leaf xx (* if the original list is empty... *)
| l', S k => iter l' k
| _, O => Leaf xx (* never happens list reduces to one elt in log(length) steps*)
end.
Definition list2bint l := iter (map Leaf l) (length l).
I haven't done any proof, but it seems that step n has the following invariant:
all the trees in the list are perfect of height n, except the last 2 that are only complete of height n (if we consider a perfect tree of height n - 1 as a complete tree of height n).
Complexity is linear.
Bruno.
- [Coq-Club] Making a List into a Tree with Structural Recursion, roconnor
- Re: [Coq-Club] Making a List into a Tree with Structural Recursion, Lionel Elie Mamane
roconnor
roconnor
- Re: [Coq-Club] Making a List into a Tree with Structural Recursion, Bruno Barras
- Re: [Coq-Club] Making a List into a Tree with Structural Recursion, Thery Laurent
roconnor
