- To: roconnor AT theorem.ca
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Making a List into a Tree with Structural Recursion
- Date: Fri, 16 Dec 2005 18:50:01 +0100
wrote:
On Fri, 16 Dec 2005, Bruno Barras wrote:I first tried something like in Laurent's post, but by merging neighbours pairwise to avoid computing the log of the length. The problem was that for lists of size 2^n+1, the last element would not grow before the last step, because the last always remains the last. So I imagined that the last element should always be merged with its neighbour. This was good since the element that is not merged would change at every step, thus avoiding the depth gap to increase.
What about this ?
Complexity is linear.
What a promising solution. I wasn't even close to thinking of anything
like this. How did you come up with it?
Not a formal reasoning but it was enough to guide me towards a solution...
Indeed, it seems the elements at depth n+1 are all on the rightmost branches, so if you want the most constrained solution, just mirror the input list and the output tree. But I'm not yet sure of that.
I have no idea if this is a classical algorithm or not.
Bruno.
- [Coq-Club] Making a List into a Tree with Structural Recursion, roconnor
- Re: [Coq-Club] Making a List into a Tree with Structural Recursion, Lionel Elie Mamane
roconnor
roconnor
Bruno Barras
roconnor
- Re: [Coq-Club] Making a List into a Tree with Structural Recursion, Bruno Barras
roconnor
- Re: [Coq-Club] Making a List into a Tree with Structural Recursion, Thery Laurent
Bruno Barras
roconnor
