- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Can't get Coq to do the refinement I want in dependent elimination
- Date: Sun, 18 Dec 2005 13:28:27 -0500
- Resent-date: Sun, 18 Dec 2005 21:37:30 -0500
- Resent-from: Stefan Monnier <monnier AT iro.umontreal.ca>
- Resent-message-id: <87zmmxhkwl.fsf-monnier+inbox AT gnu.org>
- Resent-to: coq-club AT pauillac.inria.fr
[ Apologies if this is a repeat: I tried to send it via Gmane (where I read
this list) and it appears to have disappeared in the ether. ]
Let's say I have the following code:
Inductive ULeq (k:Set) : list k -> list k -> Set :=
| ULeq_refl : forall l, ULeq l l
| ULeq_skip : forall l1 l2 x, ULeq l1 l2 -> ULeq (x::l1) (x::l2).
and want to show that
Definition test : forall k (l1:list k) l2 l3 x,
ULeq l1 l2 -> ULeq (x::l2) l3) -> ULeq (x::l1) l3.
I expected the following code to work (modulo incomplete matching,
obviously):
Definition test k (l1:list k) l2 l3 x
(PE1: ULeq l1 l2) (PE2 : ULeq (x::l2) l3)
: ULeq (x::l1) l3 :=
match PE2 in ULeq l2' l3 return ULeq (x::l1) l3 with
| ULeq_refl l => ULeq_skip x PE1
end.
but Coq actually complains
The term "ULeq_skip x PE1" has type "ULeq (x :: l1) (x :: l2)"
while it is expected to have type "ULeq (x :: l1) l"
So Coq doesn't do the type refinement in the dependent elimination like
I expect it to. My understanding right now is that Coq fails to substitute
l3 by (x::l2) or that I'm basically asking it to substitute (x::l2) by
l which it (reasonably) refuses to do.
Can someone explain to me exactly what's happening and/or how I could adjust
my code so that Coq understands what I want to do?
Stefan
- [Coq-Club] Can't get Coq to do the refinement I want in dependent elimination, Stefan Monnier
