coq-club - Re: [Coq-Club] Can't get Coq to do the refinement I want in dependent elimination
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Stefan Monnier <monnier AT iro.umontreal.ca>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Can't get Coq to do the refinement I want in dependent elimination
  • Date: Mon, 19 Dec 2005 09:15:57 +0100
Hi,
I tried to look at "test" in an interactive way :
  Definition test : forall k (l1:list k) l2 l3 x, ULeq l1 l2 ->
              ULeq (x::l2) l3 -> ULeq (x::l1) l3.
intros.
1 subgoal
 k : Set
 l1 : list k
 l2 : list k
 l3 : list k
 x : k
 H : ULeq l1 l2
 H0 : ULeq (x :: l2) l3
  ULeq (x :: l1) l3
case H0.
2 subgoals
 x : k
 H : ULeq l1 l2
  forall l : list k, ULeq (x :: l1) l
subgoal 2 is:
forall (l4 l5 : list k) (x0 : k), ULeq l4 l5 -> ULeq (x :: l1) (x0 :: l5)
The first subgoal is associed with the expected type you complained about.
    match PE2 in ULeq l2' l3 return ULeq (x::l1) l3 with
    | ULeq_refl l => ULeq_skip x PE1
    end.
When you eliminate the hypothesis PE2, you try to build a function which maps any variable
H of type (ULeq l2' l3') to a term of type ULeq (x::l1) l3'
The first case for H is a term of the form (ULeq_refl l l) ; So what you have to provide is a term of
type ULeq (x::l1) l
When dealing with such cases (eliminating hypotheses which contain some constrained variables) its sometimes
better to use inversion tactics.
  Definition test : forall k (l1:list k) l2 , ULeq l1 l2 -> forall x l3,
induction 1.
auto.
intros.
inversion H0.
constructor 2.
constructor 2.
auto.
constructor 2.
auto.
Qed.
Pierre
but Coq actually complains
  The term "ULeq_skip x PE1" has type "ULeq (x :: l1) (x :: l2)"
   while it is expected to have type "ULeq (x :: l1) l"
So Coq doesn't do the type refinement in the dependent elimination like
I expect it to.  My understanding right now is that Coq fails to substitute
l3 by (x::l2) or that I'm basically asking it to substitute (x::l2) by
l which it (reasonably) refuses to do.
Can someone explain to me exactly what's happening and/or how I could adjust
my code so that Coq understands what I want to do?
       Stefan
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
