coq-club - [Coq-Club]On the form of the axiom of description
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club]On the form of the axiom of description
  • Date: Fri, 10 Feb 2006 10:41:01 +0100
I am dissatisfied with the form of the axiom of dependent description,
as it is given in Logic/ClassicalDescription.v and the associated
theorems.
Axiom
  dependent_description :
    forall (A:Type) (B:A -> Type) (R:forall x:A, B x -> Prop),
      (forall x:A,
          exists y : B x, R x y /\ (forall y':B x, R x y' -> y = y')) ->
       exists f : forall x:A, B x, (forall x:A, R x (f x)).
This axioms gives me the existence of a function but not the possibility
to use this function easily in further definitions.  I believe a
stronger version would be the following one:
Axiom
  dependent_description' :
      (forall x:A,
       sigT (fun f : forall x:A, B x => (forall x:A, R x (f x))).
(the difference between dependent_description and dependent_description'
is that I replaced the last exists by sigT. )
I would like to know whether adding this axiom would yield an
inconsistent logic.  Morally, I would be satisfied with the idea that,
in classical logic, the functional notation of Coq is just a short-hand
for "set-theory-like" functions but I am aware that we may be navigating
close to Cantor's naive set theory
I believe the answer can fall in three categories:
1/ No problem, you can already derive dependent_description' from
   dependent_description using other axioms of classical logic that
   are thought to be sensible (a coq proof would be great).
2/ Big problem, once you do that, you can encode one of the well-known
   paradoxes (again a coq proof would be great).
3/ Nobody knows.
Does anyone have a quick answer in the direction of 1 or 2?  Does anyone
know that we don't know?
Yves
