- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]On the form of the axiom of description
- Date: Fri, 10 Feb 2006 11:22:41 +0100
On Fri, Feb 10, 2006 at 10:41:01AM +0100, Yves Bertot wrote:
> Axiom
> dependent_description' :
> forall (A:Type) (B:A -> Type) (R:forall x:A, B x -> Prop),
> (forall x:A,
> exists y : B x, R x y /\ (forall y':B x, R x y' -> y = y')) ->
> sigT (fun f : forall x:A, B x => (forall x:A, R x (f x))).
Hi Yves,
From my humble opinion, this doesn't look good. From the extraction
point of view, this amounts to say "exists f : A->B" out of nothing.
Adding additional axioms like Classical, Extensionality,
ProofIrrelevance, doesn't change the point, since those axioms live in
Prop. And my "doesn't-look-good" opinion can probably be formalized a
bit more using realizability.
In the meantime, another additional transformation gives you something
perfectly provable. But it is probably not what you want...
Lemma dependent_description'' :
(forall x:A,
sigT (fun y : B x => R x y /\ (forall y':B x, R x y' -> y =
y')))->
Proof.
intros.
exists (fun x => let (y,_) := X x in y).
intros.
destruct (X x); intuition.
Qed.
With this one, extraction is just the identity. By the way, in the
above proof, you don't even need the "R x y' -> y =y'" part (but you
would need it to prove that the answered function is the only one that
fits).
Hope that helps,
Pierre
- [Coq-Club]On the form of the axiom of description, Yves Bertot
- Re: [Coq-Club]On the form of the axiom of description, Pierre Letouzey
- Re: [Coq-Club]On the form of the axiom of description, Gérard Huet
Benjamin Werner
- Re: [Coq-Club]On the form of the axiom of description, Hugo Herbelin
- Re: [Coq-Club]On the form of the axiom of description, Benjamin Werner
