coq-club - [Coq-Club]Strings for coq
chronological Thread
I've downloaded the String definition from the Coq website
(http://coq.inria.fr/contribs/String.html), but I'm getting compiler errors.
The package contains no real information about compiling it, and I am at a
bit of a loss as to how to troubleshoot this.  Can someone provide some help?
Thanks
Rob Dockins
The error message follows:
$ coqc -v
The Coq Proof Assistant, version 8.0pl3 (Jan 2006)
compiled on Feb 08 2006 04:00:21
$ camlp4 -v
Camlp4 version 3.08.3
$ ocamlc -v
The Objective Caml compiler, version 3.08.3
Standard library directory: /usr/lib/ocaml
$ make
ocamlc -c  -I . -I /kernel -I /lib -I /library -I /parsing -I /pretyping
-I /interp -I /proofs -I /syntax -I /tactics -I /toplevel
-I /contrib/correctness -I /contrib/extraction -I /contrib/field
-I /contrib/fourier -I /contrib/graphs -I /contrib/interface
-I /contrib/jprover -I /contrib/omega -I /contrib/romega -I /contrib/ring
-I /contrib/xml -I `camlp4 -where` -pp "camlp4o -I . -I /parsing
pa_extend.cmo pa_ifdef.cmo q_MLast.cmo grammar.cma -impl" g_ascii_syntax.ml
Warning: pa_ifdef is deprecated since OCaml 3.07. Use pa_macro instead.
Error while loading "grammar.cma": file not found in path.
Preprocessor error
make: *** [g_ascii_syntax.cmo] Error 2
