coq-club - Re: [Coq-Club]Graphs in Coq
chronological Thread
  • To: nouvid-coq AT yahoo.fr
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Graphs in Coq
  • Date: Mon, 6 Mar 2006 13:37:51 +0100
On 6 Mar 2006, at 11:40, Fabrice Lemercier wrote:
I want to formalize in Coq finite directed graphs with
a relation on paths. But I cannot find an elegant
definition.
What about something like that:
* data-structures are not cluttered with sig types.
* well-formedness conditions are stated.
Require Import List.
(* My data-structure for graphs *)
Record Graph: Set :=
    Nb : nat;
    Edges : list (nat* nat);
sources_ok : forall source target, In (source,target) Edges -> source <= Nb;
target_ok : forall source target, In (source,target) Edges -> target <= Nb
Definition path := list nat.
(* What it means for a path to belong to a graph *)
Inductive path_ok (G:Graph) : path -> Prop :=
  | empty_path : path_ok  G nil
| cons_path : forall s t, In (s,t) (Edges G) -> forall p, path_ok G (t::p) -> path_ok G (s::t::p)
(* Returns the last element of a path *)
Fixpoint last (A:Set) (l:list A) {struct l}: option A :=
  match l with
    | nil => None
    | e::nil => Some e
    | e::l => last A l
  end.
Record Graph_with_relation : Set :=
(* The graph *)
    G : Graph;
(* The relation *)
    R : list (path * path);
(* well-formedness conditions *)
    R_path_ok1 : forall  p1 p2 , In (p1,p2) R -> path_ok G p1;
    R_path_ok2 : forall p1 p2 , In (p1,p2) R -> path_ok G p2;
    R_same_orig : forall  p1 p2, In (p1,p2) R -> head p1 = head p2;
    R_same_dest : forall  p1 p2 , In (p1,p2) R -> last _ p1 = last _ p2
(* You might also want to rule out the empty path *)
Frédéric Besson
