- To: Jo�o Gomes <jg AT netvisao.pt>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]problems installing Coq
- Date: Tue, 21 Mar 2006 18:08:08 +0100
João Gomes wrote:
$ make worldCheck that you have a (possibly empty) directory bin/ in coq-8.0pl3. If not, create it and try again (some decompression tools might not create empty dirs, which is nasty).
OCAMLC config/coq_config.ml
OCAMLC -o bin/coqmktop
/usr/bin/ld: cannot open output file bin/coqmktop: Arquivo ou diretório
não encontrado
collect2: ld returned 1 exit status
Error while building custom runtime system
make: ** [bin/coqmktop] Erro 2
I can't understand what is going on.
If it exists, check that it does not contain a write-protected coqmktop file. Otherwise, you might have a serious installation problem with either ocaml or gcc. Try running
LC_ALL=C make VERBOSE=1 CAMLDEBUG="-ccopt -###" bin/coqmktop
it may help spot at which stage compilation fails and why.
Hope this helps.
Bruno Barras.
- [Coq-Club]problems installing Coq, João Gomes
- Re: [Coq-Club]problems installing Coq, Bruno Barras
- Re: [Coq-Club]problems installing Coq, João Gomes
