- To: "Bruno Barras" <bruno.barras AT inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]problems installing Coq
- Date: Tue, 21 Mar 2006 19:33:40 -0000 (WET)
- Importance: Normal
Sorry, I forgot to say that I had already found the solution.
You are right. It was the simple problem of bin directory did existed. :)
Thank you for your help!
João
Bruno Barras wrote:
João Gomes wrote:
>$ make world
>OCAMLC config/coq_config.ml
>OCAMLC -o bin/coqmktop
>/usr/bin/ld: cannot open output file bin/coqmktop: Arquivo ou diretório
>não encontrado
>collect2: ld returned 1 exit status
>Error while building custom runtime system
>make: ** [bin/coqmktop] Erro 2
>I can't understand what is going on.
Check that you have a (possibly empty) directory bin/ in coq-8.0pl3. If
not, create it and try again (some decompression tools might not create
empty dirs, which is nasty).
If it exists, check that it does not contain a write-protected coqmktop
file. Otherwise, you might have a serious installation problem with
either ocaml or gcc. Try running
LC_ALL=C make VERBOSE=1 CAMLDEBUG="-ccopt -###" bin/coqmktop
it may help spot at which stage compilation fails and why.
Hope this helps.
Bruno Barras.
- [Coq-Club]problems installing Coq, João Gomes
- Re: [Coq-Club]problems installing Coq,
Bruno Barras
- Re: [Coq-Club]problems installing Coq, João Gomes
Bruno Barras
