- To: Adam Koprowski <adam.koprowski AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Equality problem.
- Date: Mon, 10 Apr 2006 14:49:28 +0100
Hi all
Adam Koprowski wrote:
Hello everybody,
During my work in Coq I encountered something that looks rather as an elementary problem but I got stucked on it nevertheless. Here is the relevant snippet:
Variable A: Set.
Inductive Test: Set :=
| Elem: A -> Test
| Pair: Test -> Test -> Test.
Fact discr: forall a b, ~a = Pair a b.
Proof. ?
How can one prove discr? I tried all varations of discriminate, injection etc. I could think of. Or is this equality not valid intuitionistically? Any indications why? Any help appreciated!
If this is a one-off problem, then some sort of induction will do nicely. If you want to do this sort of thing a lot, and especially if your cycle length gets longer than 1, eg disproving a = Pair b (Pair a c), you can prove a once-per-datatype 'no cycles' theorem following the scheme in 'A Few Constructions on Constructors' by myself, Healf Goguen and James McKinna, in proceedings of TYPES 2004.
Basically, the idea is that given some x = t, compute the tuple of proofs that x is not equal to any of the constructor-guarded subterms of t. In your case, given the above, you would get a tuple containing 'a is not a', which is quite useful.
Hope this helps
Conor
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club]Equality problem., Adam Koprowski
- Re: [Coq-Club]Equality problem., roconnor
- Re: [Coq-Club]Equality problem., Xavier Leroy
- Re: [Coq-Club]Equality problem., Andrew McCreight
- Re: [Coq-Club]Equality problem., Jean-Marc Notin
- Re: [Coq-Club]Equality problem., Conor McBride
