coq-club - Re: [Coq-Club]Applying reduction rules to generated proofs
chronological Thread
  • To: mulhern <mulhern AT gmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Applying reduction rules to generated proofs
  • Date: Tue, 25 Apr 2006 11:32:24 +0200
On Mon, 24 Apr 2006 20:08:01 -0500 mulhern
 wrote:
> Theorem name : <goal>.
> Proof.
> <lots of tactics>.
> Qed.
First if you want your proof term to be transparent (ie unfoldable),
you have to finish your proof by "Defined" instead of Qed or Save.
> Definition name_reduced := Eval cbv zeta in name.
This is the right idea but you have to tell cbv to unfold names (delta
reduction). You can try this first:
Definition name_reduced := Eval cbv zeta delta in name.
but this may give to much unfolding. You can focus the delta reduction by
this:
Definition name_reduced := Eval cbv zeta delta [name_reduced] in name.
This should do the work. [..] can contain a space separated list of
constant names.
Hope this helps.
Pierre Courtieu
> The problem with that is that I can't tell what the body of
> name_reduced consists of because I cannot Print it. When I use the
> Print command I just get
> name_reduced
