coq-club - [Coq-Club]Re: Applying reduction rules to generated proofs
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club]Re: Applying reduction rules to generated proofs
  • Date: Tue, 25 Apr 2006 13:17:46 -0500
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=B26VTrhdeAEq9M82VMqea4syuEDtLu05f0zafjf0Znd4qr4g+ZGJSAWXNdMmLodR4HTJKJTNDZEkFpPNWXSrTBwvNCw7Ih+DX3wA2mq7zxRAbab86N9jQlQQ5u+sg9A1R0Xcu5/2fHgKWsrlPkdVVyvKBxReVgm0N93g7C9Mk9Y=
Thanks all!
The key points are:
1) Make sure the original theorem is transparent.
2) Perform a delta reduction on the constant corresponding to the
original theorem in order to make the zeta reduced body visible.
-mulhern
On 4/24/06, mulhern
<mulhern AT gmail.com>
 wrote:
> Hi!
> Suppose I have developed a proof in the normal way.
> Theorem name : <goal>.
> Proof.
> <lots of tactics>.
> Qed.
> I want to apply zeta reductions to the body of the proof once it has
> been generated.
> Currently the way I do this is:
> Print name.
> Then I copy the generated output and paste it into the command.
> Definition name_reduced := Eval cbv zeta in
>   <big chunk of text goes here at the paste operation>
> Is there any way to do this through Coq instead of by this cumbersome
> and not really scalable cut and paste method?
> I have tried
> Definition name_reduced := Eval cbv zeta in name.
> The problem with that is that I can't tell what the body of
> name_reduced consists of because I cannot Print it. When I use the
> Print command I just get
> name_reduced
> My purpose in performing these reductions is to transform the proof to
> one that is more readily accepted by the refine tactic.
> -mulhern
