- From: Frederic Blanqui <Frederic.Blanqui AT loria.fr>
- To: Daniel Peng <coq AT peng.dyndns.org>
- Cc: coq-club AT pauillac.inria.fr, Paul Govereau <govereau AT eecs.harvard.edu>, amal AT eecs.harvard.edu, John Dias <dias AT eecs.harvard.edu>, Greg Morrisett <greg AT eecs.harvard.edu>
- Subject: Re: [Coq-Club]Induction schemes for not-quite mutually inductive types
- Date: Mon, 22 May 2006 10:24:19 +0200 (CEST)
On Sat, 20 May 2006, Daniel Peng wrote:
Inductive T : Set :=
| TInt
| TCode: Map T -> T (* the type of a code pointer is a partial map
from registers to types *)
| TVar : nat -> T (* deBruijn indices *)
| TForall : T -> T.
I'm having trouble with the induction principle in the TCode case.
When I induct over T, the TCode case doesn't provide any induction
hypotheses. Essentially, I want Map T and T to be mutually inductive;
however, I haven't declared them that way, and I can't seem to get a
mutual induction principle over them.
coq doesn't recognize (Map T) in the type of TCode as a recursive argument and doesn't generate the correct induction principle. you have to define it yourself. see Term/Varyadic/VTerm.v in the CoLoR library http://color.loria.fr/ for an example with list instead of Map:
Inductive term : Set :=
| Var : variable -> term
| Fun : forall f : Sig, list term -> term.
Reset term_rect.
Section term_rect.
Variables
(P : term -> Type)
(Q : terms -> Type).
Hypotheses
(H1 : forall x, P (Var x))
(H2 : forall f v, Q v -> P (Fun f v))
(H3 : Q nil)
(H4 : forall t v, P t -> Q v -> Q (t :: v)).
Fixpoint term_rect t : P t :=
match t as t return P t with
| Var x => H1 x
| Fun f v => H2 f
((fix vt_rect (v : terms) : Q v :=
match v as v return Q v with
| nil => H3
| cons t' v' => H4 (term_rect t') (vt_rect v')
end) v)
end.
End term_rect.
Definition term_ind (P : term -> Prop) (Q : terms -> Prop) := term_rect P Q.
Definition term_rec (P : term -> Set) (Q : terms -> Set) := term_rect P Q.
- [Coq-Club]Induction schemes for not-quite mutually inductive types, Daniel Peng
- Re: [Coq-Club]Induction schemes for not-quite mutually inductive types, Frederic Blanqui
