coq-club - Re: [Coq-Club]Induction schemes for not-quite mutually inductive types
chronological Thread
  • To: "Frederic Blanqui" <Frederic.Blanqui AT loria.fr>
  • Cc: coq-club AT pauillac.inria.fr, "Paul Govereau" <govereau AT eecs.harvard.edu>, amal AT eecs.harvard.edu, "John Dias" <dias AT eecs.harvard.edu>, "Greg Morrisett" <greg AT eecs.harvard.edu>
  • Subject: Re: [Coq-Club]Induction schemes for not-quite mutually inductive types
  • Date: Tue, 23 May 2006 22:58:37 -0400
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=jbgXRhbC43DapjCtaytM4xZvdLwh7/VX9fA8b6cVJMUiTEHOxy3qMR6i0rPBKqdJC3QRJKaKsWhmmbhGSJRcZd9o0+cxK4dyMK6SAbt+UOMRveVxMAc0kuDQGbVVaqj/Xh2J/MWXPAFzu3Ks/m6vNGgcFDBSaZziXqMExx+FA1c=
Thanks Frederic.  That's exactly what I was looking for.  Thank you.
Daniel
On 5/22/06, Frederic Blanqui
 wrote:
On Sat, 20 May 2006, Daniel Peng wrote:
> Inductive T : Set :=
> | TInt
> | TCode: Map T -> T (* the type of a code pointer is a partial map
> from registers to types *)
> | TVar : nat -> T (* deBruijn indices *)
> | TForall : T -> T.
> I'm having trouble with the induction principle in the TCode case.
> When I induct over T, the TCode case doesn't provide any induction
> hypotheses. Essentially, I want Map T and T to be mutually inductive;
> however, I haven't declared them that way, and I can't seem to get a
> mutual induction principle over them.
coq doesn't recognize (Map T) in the type of TCode as a recursive argument and
doesn't generate the correct induction principle. you have to define it
yourself. see Term/Varyadic/VTerm.v in the CoLoR library
http://color.loria.fr/ for an example with list instead of Map:
Inductive term : Set :=
   | Var : variable -> term
   | Fun : forall f : Sig, list term -> term.
Reset term_rect.
Section term_rect.
Variables
   (P : term -> Type)
   (Q : terms -> Type).
Hypotheses
   (H1 : forall x, P (Var x))
   (H2 : forall f v, Q v -> P (Fun f v))
   (H3 : Q nil)
   (H4 : forall t v, P t -> Q v -> Q (t :: v)).
Fixpoint term_rect t : P t :=
   match t as t return P t with
     | Var x => H1 x
     | Fun f v => H2 f
       ((fix vt_rect (v : terms) : Q v :=
         match v as v return Q v with
           | nil => H3
           | cons t' v' => H4 (term_rect t') (vt_rect v')
         end) v)
   end.
End term_rect.
Definition term_ind (P : term -> Prop) (Q : terms -> Prop) := term_rect P Q.
Definition term_rec (P : term -> Set) (Q : terms -> Set) := term_rect P Q.
