coq-club - Re: [Coq-Club]help with simple proof
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Alessandro Warth <alexwarth AT gmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]help with simple proof
  • Date: Wed, 31 May 2006 13:40:39 +0200
Hi,
Alessandro Warth wrote:
Hello,
I'm trying to use Coq to formalize a programming language that I've
been working on. Unfortunately, a few days ago I ran into trouble
while proving what (I think) should be a very simple lemma. I've spent
the past few days banging my head against the wall and have made no
progress, so I was hoping someone might be able to give me a few
pointers...
Here is the simplest formulation of that lemma that I could come up with:
Inductive AType : Set :=
| Red : nat -> AType
| Black : nat -> AType.
Inductive subtyping : AType -> AType -> Prop :=
| s_refl   : forall T,
               subtyping T T
| s_trans  : forall T1 T2 T3,
               subtyping T1 T2 ->
               subtyping T2 T3 ->
               subtyping T1 T3.
The subtyping relation you describe is the least reflexive and transitive relation, hence the
identity over AType.
Lemma L0 : forall (T T1:AType), subtyping T T1 -> T = T1.
Proof.
induction 1.
auto.
transitivity T2;[assumption | symmetry;auto].
Qed.
So, your lemma follows directly:
Lemma l : forall (n:nat) (T:AType),
          subtyping (Red n) T ->
          exists m:nat, T = (Red m).
Proof.
intros n T; exists n;symmetry;apply L0.
assumption.
Qed.
I guess this is not the relation you meant. You need perhaps the reflexive end transitive closure of
some simple relation defined on AType. Am I right ?
Hope this helps,
Pierre
This should be easy to prove, but I haven't had any luck so far. Does
anybody have any ideas about how I might be able to prove this?
Thank you kindly,
Alex Warth
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
