coq-club - Re: [Coq-Club]Mutually dependent types
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Alex Suzuki <as AT cynox.ch>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Mutually dependent types
  • Date: Tue, 06 Jun 2006 13:42:03 +0200
Hello Alex,
You can use "Inductive ... with " for defining simultaneously two inductive types:
Inductive A: Set := a : A
                  | f : B -> A
with B : Set := g : A -> B.
Similarly you can define mutually recursive functions.
Fixpoint size (x:A) : nat  :=
 match x with a => 0
            | f b => S (sizeB b)
         end
with sizeB (y:B) : nat :=
 match y with g x => S (size x) end.
Eval compute in (size (f (g a))).
2
For doing proofs by mutuial induction, use the command Scheme (an example is given in the
reference manual (trees and forests)).
Pierre
Alex Suzuki wrote:
Hello list,
I'm a CS student at ETH Zurich and I'm using Coq to formalize a
translation from Java Bytecode to a guarded command language used
for verification. This is probably not the last question regarding
Coq from my side. ;-)
When a situation arises where we have types that depend on each
other, how do you do write this in Coq?
Inductive A: Set :=
  | A1
  | A2 (x: B).
Inductive B: Set :=
  | B1
  | B2 (x: A).
This will not work as Coq will complain that the reference B was
not found in the current environment. Is there some way to
"forward declare" type B, or am I doing something very wrong? :)
Regards,
  Alex
