- From: Charles Bouillaguet <Charles.Bouillaguet AT crans.org>
- To: Alex Suzuki <as AT cynox.ch>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Mutually dependent types
- Date: Tue, 06 Jun 2006 06:59:43 -0400
Hi,
I think that what you want is :
Inductive A: Set :=
| A1
| A2 (x: B)
with B: Set :=
| B1
| B2 (x: A).
You may also want to define mutually recursive induction principle. You should probably read the section 10.3, about "Scheme" in the reference manual. You'll find some example there, too.
Good luck !
Charles Bouillaguet
Alex Suzuki wrote:
Hello list,
I'm a CS student at ETH Zurich and I'm using Coq to formalize a
translation from Java Bytecode to a guarded command language used
for verification. This is probably not the last question regarding
Coq from my side. ;-)
When a situation arises where we have types that depend on each
other, how do you do write this in Coq?
Inductive A: Set :=
| A1
| A2 (x: B).
Inductive B: Set :=
| B1
| B2 (x: A).
This will not work as Coq will complain that the reference B was
not found in the current environment. Is there some way to
"forward declare" type B, or am I doing something very wrong? :)
Regards,
Alex
- [Coq-Club]Mutually dependent types, Alex Suzuki
- Re: [Coq-Club]Mutually dependent types, Charles Bouillaguet
Pierre Casteran
- Re: [Coq-Club]Mutually dependent types, Alex Suzuki
- Re: [Coq-Club]Mutually dependent types, Lionel Elie Mamane
