coq-club - Re: [Coq-Club]PO in coq
chronological Thread
  • To: Frederic Peschanski <Frederic.Peschanski AT lip6.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]PO in coq
  • Date: Mon, 7 Aug 2006 16:14:57 +0200 (CEST)
On Mon, 7 Aug 2006, Frederic Peschanski wrote:
Dear all,
Hi,
The second question is more practical, I define bottom and top, e.g.:
Variable A : Type.
Variable R : Relation.
Definition porder_bottom : Prop :=
exists bottom : A, forall x : A, (R bottom x).
Definition porder_top : Prop :=
exists top : A, forall x : A, (R x top).
I can prove easily that (nat,le) as O as bottom, but I cannot prove
that it has no top (i.e ~(porder_top nat le) )
In classical reasoning, I would prove that forall y:nat, exists x:nat, ~(le x y)
and use this to contradict the existence of a top.
But even with Classical imported, I cannot do the proof.
Actually, you can do a constructive proof for proving your second
property. For instance, as follows.
Require Import Arith.
Section PO.
  Variable A : Type.
  Definition Relation := A -> A -> Prop.
End PO.
Lemma no_top_in_nat: ~(porder_top nat le).
Proof.
  unfold not.
  unfold porder_top.
  intros.
  induction H.
  absurd (S x <= x).
  apply le_Sn_n. trivial.
Qed.
Vincent Cremet.
