- From: David Pichardie <david.pichardie AT irisa.fr>
- To: Frederic Peschanski <Frederic.Peschanski AT lip6.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]PO in coq
- Date: Mon, 7 Aug 2006 16:31:47 +0200
Dear Frederic,
In fact, I do not really understand what Inhabited means.
So my first question is: how would I prove that (nat,le) is a partial order in this
setting ?
I'm not an intensive user of this Ensemble library. I frequently prefer to use my own definitions according to the problem I want to solve.
Remember that doing "set theoretical" proof in Coq is not always the easiest way.
However I have a script to solve your first question. (Inhabited A Car) is an inductive with only one constructor. It a synonym to (exists x:A, In x Car).
Require Export Partial_Order.
Require Export Arith.
Definition all_nat : Ensemble nat := fun _ => True.
Lemma all_nat_inhabited : Inhabited nat all_nat.
Proof.
exists 0.
unfold In, all_nat; trivial.
Qed.
Lemma nat_le_order : Order nat le.
Proof.
split.
exact le_refl.
exact le_trans.
exact le_antisym.
Qed.
Definition all_nat_le_PO : PO nat :=
Definition_of_PO
nat
all_nat
le
all_nat_inhabited
nat_le_order.
Frederic Peschanski wrote :
I can prove easily that (nat,le) as O as bottom, but I cannot prove
that it has no top (i.e ~(porder_top nat le) )
Concerning this second question, an induction is sufficient to prove what you want.
Require Export Relations_1.
Require Export Omega.
Section po.
Variable A : Type.
Variable R : Relation A.
Definition porder_bottom : Prop :=
exists bottom : A, forall x : A, (R bottom x).
Definition porder_top : Prop :=
exists top : A, forall x : A, (R x top).
End po.
Lemma no_top_aux : forall n,
~ (forall x : nat, x <= n).
Proof.
induction n; intro.
generalize (H 1); omega.
elim IHn; intros.
generalize (H (S x)); omega.
Qed.
Theorem no_top : ~(porder_top nat le).
Proof.
intros (top,Htop).
elim no_top_aux with top; assumption.
Qed.
Hope this helps,
David.
- [Coq-Club]PO in coq, Frederic Peschanski
- Re: [Coq-Club]PO in coq, Vincent Cremet
- Re: [Coq-Club]PO in coq, David Pichardie
