coq-club - Re: [Coq-Club]How Can We Use Modules in Practice?
chronological Thread
  • From: Andrew McCreight <andrew.mccreight AT yale.edu>
  • To: roconnor AT theorem.ca
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club]How Can We Use Modules in Practice?
  • Date: Tue, 22 Aug 2006 14:30:43 -0400 (EDT)
Hi,
I've written a functorized implementation of finite sets implemented using lists. The modules have worked pretty well there. I didn't have the problem that you did with export. For me, it works just fine, although I exported at the top level of the file instead of within a module. Maybe that's the difference.
I also encountered the second problem, where the names are not quite what you'd like. This is a problem when the arguments are actual nat and you try to use Omega, because Omega says that it cannot operate on that type, so you have to do some unfolding. A brute force way around this would be to write an unfolding tactic, but I haven't bothered.
-Andrew
On Tue, 22 Aug 2006,
 wrote:
I've written a small development of inequalities about Q for the new Q library in 8.1beta. Rather than again repeating the same theorems about Z, I've written a module that gives theorems for inequalities over any ordered ring. The idea was that the same module can be used to give theorems for Z, Q, and R in a uniform way. However, I have encountered two problems.
In my functor development I have theorems with names like plus_lt_0_compat. My idea was to collect theorems from this functor and other functors into the a module called Q. Thus the user would access the lemma by the name Q.plus_lt_compat, and similarly Z.plus_lt_compat for Z. However my attempts to do this
Module Q.
Module QOrderedRing := OrderedRing.OrderedRing QSig.
Export QOrderedRing.
End Q.
do not seem to work. :(
Another more serious problem is that the statement of the theorems in the module refer to the names of the module type parameters, rather than the names of the parameters given in the module signature. So, after applying Q.QOrderedRing.plus_lt_0_compat, one get the goals:
______________________________________(1/2)
QSig.lt QSig.zero x
______________________________________(2/2)
QSig.lt QSig.zero y
instead of the nice
0 < x
0 < y
Both these problems could be solved by writing out for each theorem an new definition with the nice signature, such as
Definition Qplus_lt_0_compat : forall n m:Q, 0 < n -> 0 < m -> 0 < n + m := Q.QOrderedRing.plus_lt_0_compat.
But this seems to largely defeat the purpose of using modules. If someone adds a new theorem to the module, then every type that uses the module will have to add a new definition.
Has anyone had any practical success using modules to modularise theories?
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
