- To: Andrew McCreight <andrew.mccreight AT yale.edu>
- Cc: roconnor AT theorem.ca, Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club]How Can We Use Modules in Practice?
- Date: Tue, 22 Aug 2006 16:56:01 -0400
On Tuesday 22 August 2006 14:30, Andrew McCreight wrote:
> Hi,
> I've written a functorized implementation of finite sets implemented using
> lists. The modules have worked pretty well there. I didn't have the
> problem that you did with export. For me, it works just fine, although I
> exported at the top level of the file instead of within a module. Maybe
> that's the difference.
> I also encountered the second problem, where the names are not quite what
> you'd like. This is a problem when the arguments are actual nat and you
> try to use Omega, because Omega says that it cannot operate on that type,
> so you have to do some unfolding. A brute force way around this would be
> to write an unfolding tactic, but I haven't bothered.
I'd just like to mention I've also had some issues with folding/unfolding
when
using modules. Sometimes I have to use explicit 'change ... with' tactics to
apply rewrites. I've also had cases where the Coq interface won't recognize
terms I type (in 'apply with ...' clauses or as arguments to 'set :='
or 'pattern' for example) that I think are due to the same unfolding issues.
I don't recall having to do stuff like this when I'm not using modules. It's
really quite irritating.
Rob Dockins
Talk softly and drive a Sherman tank.
Laugh hard, it's a long way to the bank.
-- TMBG
- [Coq-Club]How Can We Use Modules in Practice?, roconnor
- Re: [Coq-Club]How Can We Use Modules in Practice?,
Andrew McCreight
- Re: [Coq-Club]How Can We Use Modules in Practice?, Robert Dockins
Andrew McCreight
