coq-club - [Coq-Club]Modules in Coq 8.1gamma - Strange errors
chronological Thread
  • From: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club]Modules in Coq 8.1gamma - Strange errors
  • Date: Wed, 29 Nov 2006 00:20:35 -0500
Hi everyone,
I'm working in Coq 8.1gamma. The errors I'm seeing from the module system are confusing to me, so I'm hoping that I can find some help from this list. As far as I can tell, I must be misunderstanding something important about the difference between ":" and "<:" when ascribing types to modules. Two small examples showing exactly what confuses me are below.
Thanks,
Brian
All of my examples assume the following libraries are imported:
  Require Import DecidableType.
  Require Import DecidableTypeEx.
EXAMPLE 1: Consider the following code.
  Module Type Test.
   Declare Module E : DecidableType.
  End Test.
  Module Make (X : DecidableType) <: Test with Module E := X.
    Module E : DecidableType := X.
  End Make.
The "End Make" results in the following error: "User error: Signature components for label t do not match". My question(s): where is this label t coming from and why? If I change the line
to
    Module E <: DecidableType := X.
this example goes through without problem. I'm not sure what the meaningful difference here is. In both cases, E is defined by a module expression which has an appropriate module type, and I don't see what the visibility of the things inside E has to do with anything.
EXAMPLE 2:  Extending the above example, consider the following.
  Module Type Test.
  End Test.
  End Make.
  Module N' : DecidableType := Nat_as_DT.
  Module Q : Test with Module E := N' := Make N'.
That works without problem.  If I change the line
to
  Module N' <: DecidableType := Nat_as_DT.
the definition of Q gives me the error "User error: No such label OF". Why is this the case? Trying to define Q directly, via
  Module Q : Test with Module E := Nat_as_DT := Make Nat_as_DT.
results in the same error.
