- To: Tom Harke <harke AT cs.pdx.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Using a Prop to bound recursion
- Date: Tue, 05 Dec 2006 18:23:38 -0800
Tom Harke wrote:
Suppose I have an infinite stream, and I'm looking for a special element
in it. I don't know where it is, I only know that it definitely occurs.
In fact, I've got a Prop demonstrating its existence.
Is it possible to write a function in Set which will find this element?
I haven't been able to, and I can't tell whether I should be able to.
My intuition is that this is impossible. Since you aren't allowed to eliminate values of types in Prop to construct values of types in Set, I can't see how you could get any "information flow" from the existential witness to the return value of your function. I don't know how to prove that it's impossible to write your function, though.
I'm new to Coq and a bit unclear on its limitations.
I wouldn't call this a limitation. Especially if you turn on impredicativity of Set, you can ignore Prop altogether and not have this problem. The reason to choose Prop versions of constructs in the first place is because you _want_ to prevent functions like yours from being written!
- [Coq-Club]Using a Prop to bound recursion, Tom Harke
- Re: [Coq-Club]Using a Prop to bound recursion, Adam Chlipala
- Re: [Coq-Club]Using a Prop to bound recursion, Christine Paulin
- Re: [Coq-Club]Using a Prop to bound recursion, roconnor
- <Possible follow-ups>
- Re: [Coq-Club]Using a Prop to bound recursion, Yves Bertot
