coq-club - Re: [Coq-Club]Using a Prop to bound recursion
chronological Thread
  • To: Adam Chlipala <adamc AT cs.berkeley.edu>
  • Cc: Tom Harke <harke AT cs.pdx.edu>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Using a Prop to bound recursion
  • Date: Wed, 6 Dec 2006 08:18:36 +0100
Adam Chlipala writes:
 > Tom Harke wrote:
 > > Suppose I have an infinite stream, and I'm looking for a special element
 > > in it.  I don't know where it is, I only know that it definitely occurs.
 > > In fact, I've got a Prop demonstrating its existence.
 > > Is it possible to write a function in Set which will find this element?
 > > I haven't been able to, and I can't tell whether I should be able to.
 > My intuition is that this is impossible.  Since you aren't allowed to
 > eliminate values of types in Prop to construct values of types in Set, I
 > can't see how you could get any "information flow" from the existential
 > witness to the return value of your function.  I don't know how to prove
 > that it's impossible to write your function, though.
The situation is not so simple because the fixpoint rule allows to
define a function in Set with a decreasing argument in Prop. This is
used for well-founded recursion and can be used in that case as well.
The trick is to define exists j, p (nth j s) as an inductive relation
Inductive ok (p:A -> Prop) : Stream -> Prop :=
     ok_direct : forall s,p (head s) -> ok p s
   | ok_next : forall s, ok p (tail s) -> ok p s.
It is easy to prove the equivalence with your definition.
Then the following lemma is such that (ok_inv p s occ H) is a term
structurally smaller than occ
Lemma ok_inv : forall p s, ok p s ->~p (head s) ->  ok p (tail s).
destruct 1; intro; trivial.
case H0; auto.
Defined.
It is then possible to define your seek function by structural
induction over the proof of ok p s.
Fixpoint seek (p:A -> Prop) (pdec : forall x, {p x}+{~p x})
                     (s:Stream) (occ:ok p s) {struct occ}: A :=
match pdec (head s) with
               left _ => head s
           |   right H => seek p pdec (tail s) (ok_inv p s occ H)
       end.
You may have a look at Yves Bertot paper TLCA 95 on filters on
CoInductive Streams.
Best regards
Christine Paulin
 > > I'm new to Coq and a bit unclear on its limitations.
 > I wouldn't call this a limitation.  Especially if you turn on
 > impredicativity of Set, you can ignore Prop altogether and not have this
 > problem.  The reason to choose Prop versions of constructs in the first
 > place is because you _want_ to prevent functions like yours from being
 > written!
 > Bug reports: http://coq.inria.fr/bin/coq-bugs
 > Archives: http://pauillac.inria.fr/pipermail/coq-club
 >           http://pauillac.inria.fr/bin/wilma/coq-club
 > Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
  Christine Paulin-Mohring             mailto :
Christine.Paulin AT lri.fr
  INRIA Futurs - PROVAL
        Parc club Orsay Université, Bat N, Zac des Vignes
        4, rue Jacques Monod, 91893 Orsay cedex
  &     LRI, Bat 490, UMR 8623 CNRS,
        Université Paris Sud,  91405 Orsay Cedex
  tel : (+33) (0)1 72 92 59 05         fax : (+33) (0)1 60 19 69 63
