coq-club - Re: [Coq-Club]Problems writing programs with tactics
chronological Thread
  • From: Benjamin Gregoire <Benjamin.Gregoire AT sophia.inria.fr>
  • To: Sean Wilson <sean.wilson AT ed.ac.uk>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Problems writing programs with tactics
  • Date: Wed, 06 Dec 2006 11:47:18 +0100
Sean Wilson wrote:
Hi,
I have a couple of questions about programming in Coq that I cannot seem to work out. As an example of my issue, I want to program a list 'take' function that takes items n from the front of a list e.g. take [1,2,3] 1 = [1] and take [1,2,3] 2 = [1,2]. In ML, you might implement it with:
fun take (_, 0)    = [ ]
| take ([ ], _)    = raise Subscript
| take (h :: t, n) = h::take (t, n – 1) handle Overflow => raise Subscript
You can write a similar version directly in Coq, but I'm interested in how to write it using only the tactic language (I find this easier when I need to use dependently typed terms). Here is one of my attempts:
Definition take : forall (x:list nat) (n:nat), list nat.
intros.
induction n.
 apply (nil:list nat). (* Counter is zero *)
 induction x.
 apply (nil:list nat).(* This case shouldn't happen; return nil by default *)
 apply (cons a IHn). (* Recursive call *)
Qed.
The actual Coq term produced isn't very readable, so here is the extracted version:
let rec take x = function
 | O -> Nil
 | S n0 ->
     (match x with
        | Nil -> Nil
        | Cons (a, l) -> Cons (a, (take x n0)))
This is wrong: the last match clause should be Cons (a, (take l n0))). The counter is getting smaller each recursive call but the list is not. If I use "apply (cons a IHx)" instead, only the list gets smaller each call; I need both to get smaller for it to work but none of the terms in the hypothesis does this.
  Your script is wrong.
What you want is the following induction hypothesis: IHn: forall (l:list nat), list nat. (* and not IHn: list nat. *)
To do so (using the induction tactic) you should first generalize l (i.e. x) before the induction :
    Definition take1 : forall (l:list nat) (n:nat), list nat.
     intros l n.
     generalize l;clear l;induction n.
     exact (fun l => @nil nat).
     intros [|a l].
     exact (@nil nat).
     exact (a::IHn l).
   Defined.
  Print take1.
If you prefere a more "readable" version use the following script :
 Definition take2 : forall (l:list nat) (n:nat), list nat.
   fix take_rec 2.
   intros l [|x].
   exact (@nil nat).
   destruct l as [|a l].
   exact (@nil nat).
   exact (a::take_rec l x).
 Defined.
 Print take2.
If you prefer the first script and but you whant a more readable version :
Definition take3 := Eval cbv beta delta [take1 nat_rect nat_rec] zeta in take1.
   Print take3.
 Remark that this version is not exactly what you expect.
I can get the result I want by using the refine tactic:
Definition take2 : forall (x:list nat) (n:nat), list nat.
refine (fix take2 (x:list nat) (n:nat) {struct n} : list nat := _).
(* Same as above up to the last line... *)
 apply (cons a (take2 x n)).
Qed.
  The fix tactic.
Is there any way to get this result without using refine? I'd like to know if there was a way to do this.
Closer to the actual example I want to do is this, using a sigma type to constrain the value of the counter:
Definition take3 : forall (x:list nat) (n:{i:nat | i <= length(x)}), list nat.
refine (fix take2 (x:list nat) (n:{i:nat | i <= length(x)}) {struct n} : list nat := _).
destruct n as [n].
induction n.
 induction x.
 apply (nil:list nat). (* error *)
 (* Construct the counter term (with proof) for the recursive call *)
 assert({i : nat | i <= length x}).
 exists n.
 intuition.
 apply (cons a (take3 x H)).
Qed.
This is the same as the previous example with refine except there is a little more work in taking apart and building sigma type terms for the counter. However, I get an error at the Qed. Coq says:
Recursive call to take3 has principal argument equal to
"exist (fun i : nat => i <= length l2) n2
  (let H :=
     let H :=
       fun _ : n2 <= length l2 =>
       let H1 := F0 l2 (fun _ : n2 <= length l2 => l2) in l2 in
     F0 l2 H in
   lt_n_Sm_le n2 (length l2) l3)"
instead of a subterm of n
I suspect that this is because what I said was my structurally recursive parameter is not accurate. What I really want to say in the "refine" line is that take3 is structurally recursive on the first member of the pair that is n. I tried to do this with:
refine (fix take2 (x:list nat) (n:{i:nat | i <= length(x)}) {struct (proj1_sig n)} : list nat := _).
Coq gives this error:
"Syntax error: [Prim.name] expected after 'struct' (in [fixannot])"
How can I get this to work?
Any help would be greatly appreciated.
Regards,
Sean
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
