- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: Sean Wilson <sean.wilson AT ed.ac.uk>
- Subject: Re: [Coq-Club]Problems writing programs with tactics
- Date: Wed, 6 Dec 2006 12:49:26 +0100
- Resent-date: Wed, 6 Dec 2006 12:50:14 +0100
- Resent-from: Pierre.Letouzey AT pps.jussieu.fr
- Resent-message-id: <20061206115014.GC24395 AT uranium.pps.jussieu.fr>
- Resent-to: coq-club AT pauillac.inria.fr
On Mon, Dec 04, 2006 at 09:45:50PM +0000, Sean Wilson wrote:
> You can write a similar version directly in Coq, but I'm interested in how
> to
> write it using only the tactic language (I find this easier when I need to
> use dependently typed terms). Here is one of my attempts:
> Definition take : forall (x:list nat) (n:nat), list nat.
> intros.
> induction n.
> apply (nil:list nat). (* Counter is zero *)
> induction x.
> apply (nil:list nat).(* This case shouldn't happen; return nil by default
> apply (cons a IHn). (* Recursive call *)
> Qed.
Two points in addition to Benjamin's answer:
First, the easiest way to get the right generalisation of x is ... to
swap the order of n and x in the signature of take. If this order
of parameters is crucial, you can define later a
take_rightorder x n := take n x.
Secondly, building via tactics such a function whose final type is not
dependent (list nat, nat, etc) is higly error-prone: There is always
the temptation to take a shortcut like "apply nil" or "apply IHn", and
as soon as the type is right, Coq can't pinpoint the mistake for
you. So my advice is: if you want to use tactics, let's prove a few
things on the way... For instance, your function take may become:
Require Import Arith.
Require Import Min.
Require Import List.
Definition take : forall (n:nat)(x:list nat),
{ y : list nat | length y = min n (length x) /\ exists z, x = y++z}.
Proof.
induction n.
exists (nil:list nat).
(* start justification *)
split; simpl; auto.
exists x; auto.
(* end justification *)
destruct x as [ | a l ]. (* btw, no induction needed here *)
split; simpl; auto.
exists (nil:list nat); auto.
destruct (IHn l) as [y Hy].
exists (a::y).
split; simpl; intuition.
destruct H0 as [z Hz].
exists z; simpl; subst l; auto.
Qed.
Extraction take. (* produce back your desired pure function *)
Best regards,
Pierre Letouzey
PS: Can somebody explain to me why firstorder isn't able to solve
goals like:
exists z : list nat, x = z
or
exists z : list nat, nil = z
- [Coq-Club]Hi! I'm new with Coq!, Alfonso Nishikawa
- Re: [Coq-Club]Hi! I'm new with Coq!,
Haoyang Wang
- [Coq-Club]Problems writing programs with tactics,
Sean Wilson
- Re: [Coq-Club]Problems writing programs with tactics, Benjamin Gregoire
- Re: [Coq-Club]Problems writing programs with tactics, Pierre Letouzey
Sean Wilson
Haoyang Wang
