- To: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]instantiating an inner existential
- Date: Wed, 31 Jan 2007 05:04:06 -0500 (EST)
On Wed, 31 Jan 2007, Keiko Nakata wrote:
Hello,
How can I instantiate an inner existential?
Suppose P and Q are of Prop and I have a subgoal :
exists i : Z, (P /\ (exists j : Z, Q))
I know that j does not depend on i and want to instantiate j first
with, say an integer 3, so as to make the subgoal look simpler.
It would be nicer if I can also instantiate j first with an object
which depends on i (e.g., i+3).
I believe that the only way to do this is by inserting a cut, by either using the cut or assert tactics.
cut (exists i : Z, (P /\ (Q 3)).
In a ``normal'' proof you would just wait to instantiate the j. I suppose if your Q is a particularly complex expression that is greatly simplified by instantiating j, then putting in a cut is quite resonable. OTOH, if Q is particularly complicated, then you probably ought to create a function for it, so that the body is simply (Q j). Then you can go through the proof until you get the the exists j, instantiate it with 3, and then unfold and simplify Q.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club]instantiating an inner existential, Keiko Nakata
- Re: [Coq-Club]instantiating an inner existential, roconnor
Benjamin Werner
Pierre Casteran
- Re: [Coq-Club]instantiating an inner existential, Benjamin Werner
Pierre Casteran
