- From: Benjamin Werner <benjamin.werner AT inria.fr>
- To: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]instantiating an inner existential
- Date: Wed, 31 Jan 2007 11:06:43 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:in-reply-to:references:mime-version:content-type:message-id:cc:content-transfer-encoding:from:subject:date:to:x-mailer:sender; b=TD7h1+CyMI/IXp2PMw44MD4tsoycXmpZgTLUNwNyX7aCjiDcdSMAI46uO9uCKi8SOh9xgao3p5xK5D9BYXvNzwsxCkA4Y+bnzx7PUB6/l8Gane1+MeDImJolkYkXGx+SGwuI2enkAlGXwAgiuE0vBFUNn2iMHZiRBvIEko3tW+A=
Hi,
It seems the simplest is to first prove the ad-hoc
lemma :
Lemma ex_perm : forall A B : Type, forall P : A -> B -> Prop,
(exists x:A, exists y:B, P x y) ->
(exists y:B, exists x : A, P x y).
Proof.
intros A B P [x [y p]]; exists y; exists x; trivial.
Qed.
(* test on a stupid example *)
Goal exists x:nat, exists y : nat, x=y.
apply ex_perm; exists 3.
I hope it works also when the right-hand part is less
simple.
Cheers,
Benjamin
Le 31 janv. 07 à 10:39, Keiko Nakata a écrit :
Hello,
How can I instantiate an inner existential?
Suppose P and Q are of Prop and I have a subgoal :
exists i : Z, (P /\ (exists j : Z, Q))
I know that j does not depend on i and want to instantiate j first
with, say an integer 3, so as to make the subgoal look simpler.
It would be nicer if I can also instantiate j first with an object
which depends on i (e.g., i+3).
With best regards,
Keiko
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club]instantiating an inner existential, Keiko Nakata
- Re: [Coq-Club]instantiating an inner existential, roconnor
- Re: [Coq-Club]instantiating an inner existential, Benjamin Werner
Pierre Casteran
Pierre Casteran
