- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]and_rec
- Date: Tue, 6 Mar 2007 13:10:28 +0000
Hi,
I'm probably doing something that isn't allowed, but here goes:
somewhere in a proof, I get the following subgoal (this is a reduced,
self-contained example):
1 subgoal
list : Set
P : list -> Prop
Q : list -> Prop
x0 : list
p0 : P x0 /\ Q x0
H : P x0
H1 : Qc (exist (fun l : list => P l) x0 H)
______________________________________(1/1)
Qc
(and_rec (fun (H0 : P x0) (_ : Q x0) => exist (fun l : list => P l) x0 H0)
p0)
I should think that this should be trivial to prove, since I should think that
the and_rec can be reduced to its result (in which case the proof can be
completed by assumption H1); but calling simpl doesn't do anything.
The problem is (I think) is that and_rec can only be reduced if the
argument has the form (conj _ _). Now, p0 does not have that form, but
the type of p0 is (P x0 /\ Q x0). Given the definition of /\:
Inductive and (A : Prop) (B : Prop) : Prop := conj : A -> B -> A /\ B
I would think if if I have a proof of type A /\ B, I must be able to
show that the structure of that proof must be conj _ _; and hence, I
should be able to simplify my and_rec, above. But I don't seem to be
able to prove the following lemma:
Lemma and_conj : forall (A B:Prop) (pf : A /\ B),
exists pa : A, exists pb : B, pf = conj pa pb.
Is there a good reason why I can't prove that, other than the fact that
I'm still very much a beginner with Coq?
Thanks!
Edsko
- [Coq-Club]and_rec, Edsko de Vries
- Re: [Coq-Club]and_rec,
jean-francois . monin
Edsko de Vries
Pierre Castéran
- [Coq-Club]Xml and coq8.1, Thery Laurent
Pierre Castéran
Edsko de Vries
Benjamin Werner
- Re: [Coq-Club]and_rec, Edsko de Vries
- Re: [Coq-Club]and_rec, Jean.Duprat
