- From: Pierre Cast�ran <pierre.casteran AT labri.fr>
- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: jean-francois.monin AT imag.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]and_rec
- Date: Tue, 06 Mar 2007 17:54:15 +0100
Quoting Edsko de Vries
<devriese AT cs.tcd.ie>:
Hi,
You can also derive another elimination principle, then use it with elim:
Lemma and_rect2 : forall (A B:Prop)(P:A/\B->Type),
(forall a b, P (conj a b)) -> forall c:A/\B, P c.
Proof.
intros A B P H c;case c.
auto.
Qed.
Lemma and_conj : forall (A B:Prop) (pf : A /\ B),
exists pa : A, exists pb : B, pf = conj pa pb.
Proof.
intros.
elim pf using and_rect2.
intros a b; exists a; exists b; auto.
Qed.
It seems that the tactic "elim" (whithout "using") applies a default
elimination principle, which is not always the useful one, whereas
"case" is more basic.
Pierre
On Tue, Mar 06, 2007 at 02:51:52PM +0100,
wrote:
Hi,
I did'nt read the complicated part, but at least:
> I would think if if I have a proof of type A /\ B, I must be able to
> show that the structure of that proof must be conj _ _; and hence, I
> should be able to simplify my and_rec, above. But I don't seem to be
> able to prove the following lemma:
intros. case pf. intros a b.
exists a. exists b.
reflexivity.
Qed.
Aaargh. Okay. That was easy :) Thanks! I had tried both (elim pf) and
(inversion pf), but neither worked; I hadn't tried (case pf). I don't
really understand why (case pf) works, but the other two don't. I guess
it's back to Coq'Art for me :)
Thanks!
Edsko
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Pierre Castéran
- [Coq-Club]and_rec, Edsko de Vries
- Re: [Coq-Club]and_rec,
jean-francois . monin
Edsko de Vries
- Re: [Coq-Club]and_rec, Pierre Castéran
- [Coq-Club]Xml and coq8.1, Thery Laurent
Edsko de Vries
Benjamin Werner
- Re: [Coq-Club]and_rec, Edsko de Vries
- Re: [Coq-Club]and_rec, Jean.Duprat
