- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Non-variable arguments in proof by induction
- Date: Mon, 12 Mar 2007 15:09:08 +0000
Hey,
> There are still some problems with these definitions:
> your types Term and welltyped are empty (no base case), so any
> proposition of the
> forms "forall t:Term, P t "and "forall G t, welltyped G t -> ..." are
> trivially provable.
Well, yes, that's true, but that's not true in the full proof. For the
base cases, Q will have to proven differently; I just tried to make the
example as small as I could possibly make it.
> Moreover, shouldn't context be an inductive type , with f g (and
> empty_context) as constructors ?
I dont understand, why should that be the case? My "real" definition of
a context is a association list with the property that it means any
variable to at most one type:
Definition propCxt (l : list (Var * type)) :=
forall (x:Var) (T1 T2:type), In (x,T1) l /\ In (x,T2) l -> T1 = T2.
Definition context : Set := {l : list (Var * type) | propCxt l}.
But I figured that for the same of a minimal example, I'd abstract away
from that. f and g are different calls to a function "upd" which updates
the context in a particular way.
I do think however that my "minimal" example is in fact self-contained;
it should be possible to complete the proof (granted, taking advantage
of the fact that the terms don't have a base case will allow you to
prove anything, but that's beside the point).
Edsko
- [Coq-Club]Non-variable arguments in proof by induction, Edsko de Vries
- Message not available
- Re: [Coq-Club]Non-variable arguments in proof by induction, Edsko de Vries
Edsko de Vries
Edsko de Vries
- <Possible follow-ups>
- Re: [Coq-Club]Non-variable arguments in proof by induction, Yves Bertot
