coq-club - Re: [Coq-Club]Defining function with dependent structure in goal
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: rcp AT Cs.Nott.AC.UK
  • Subject: Re: [Coq-Club]Defining function with dependent structure in goal
  • Date: Mon, 12 Mar 2007 08:36:45 -0700
 wrote:
I will like to examine the cases of i, so should think "dependent inversion i" should do the trick. However, this does not help. Can anyone suggest a way to proceed?
I don't have a quick solution for your particular case, but the way that I handle such situations is to prove alternate inversion principles manually. Here's an example for a significantly simpler inversion dilemma that I've encountered. Advice from others on how to improve this implementation would be very interesting to me!
Require Import List.
Set Implicit Arguments.
Section Var.
 Variable dom : Set.
 Inductive Var : list dom -> dom -> Set :=
   | First : forall G t, Var (t :: G) t
   | Next : forall G t t', Var G t -> Var (t' :: G) t.
 Lemma Var_invert'
   : forall P : forall (t' : dom) l t, Var (t' :: l) t -> Prop,
     (forall G t, P t G t (First G t)) ->
     (forall G t t' v,
   P t' G t (Next t' v)) ->
     forall l t v,
   match l return (Var l t -> Prop) with
     | nil => fun _ => True
     | _ => fun v => P _ _ _ v
   end v.
   intros.
   destruct v; auto.
 Qed.
 Theorem Var_invert
     (forall G t t' v,
     forall t' l t v, P t' l t v.
   intros.
   generalize (Var_invert' P).
   intuition.
   generalize (H1 (t' :: l)).
   trivial.
 Qed.
End Var.
