- From: Benjamin Werner <Benjamin.Werner AT inria.fr>
- To: Benjamin Pierce <bcpierce AT cis.upenn.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Coq under Proof General on OSX
- Date: Tue, 13 Mar 2007 14:29:28 +0100
I am sorry for my previous message. Actually I use the cvs version
of PG of some time ago and it works. I hope PG did not change much since.
Here is what Pierre advised me to do :
- take coq V8.1
- get w cvs version of pg :
cvs -d
:pserver:anon AT cvs.inf.ed.ac.uk:/disk/cvs/proofgen
login
---> mdp: anon
cvs -d :pserver:anon AT cvs.inf.ed.ac.uk:/disk/cvs/proofgen checkout ProofGeneral
- put in you .emacs:
(setq coq-utf-safe t)
I did not re-check since I did the cvs checkout.
Good luck,
B
Le 13 mars 07 à 14:11, Benjamin Pierce a écrit :
I've been having trouble getting (the latest) Proof General to work with Coq (8.1) on a (10.4.8 intel) Mac: everything seems to load fine when I visit a .v file, but the first thing that I do that requires starting Coq hangs.
It appears this may be an instance of the infamous "locale bug" -- #1 in the PG FAQ:
http://proofgeneral.inf.ed.ac.uk/FAQ
If so, then the workaround is to set my locale to something else so that the bytestream coming from Coq is not interpreted by Emacs as UTF-8. But I'm not sure how to do this on a Mac, or what would be a good alternative setting.
If someone else has solved this problem, I'd be grateful for a little recipe...
Thanks,
Benjamin
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club]Coq under Proof General on OSX, Benjamin Pierce
- Re: [Coq-Club]Coq under Proof General on OSX, Benjamin Werner
- Re: [Coq-Club]Coq under Proof General on OSX, Pierre Courtieu
