- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]Coq under Proof General on OSX
- Date: Tue, 13 Mar 2007 09:11:56 -0400
I've been having trouble getting (the latest) Proof General to work with Coq (8.1) on a (10.4.8 intel) Mac: everything seems to load fine when I visit a .v file, but the first thing that I do that requires starting Coq hangs.
It appears this may be an instance of the infamous "locale bug" -- #1 in the PG FAQ:
http://proofgeneral.inf.ed.ac.uk/FAQ
If so, then the workaround is to set my locale to something else so that the bytestream coming from Coq is not interpreted by Emacs as UTF-8. But I'm not sure how to do this on a Mac, or what would be a good alternative setting.
If someone else has solved this problem, I'd be grateful for a little recipe...
Thanks,
Benjamin
- [Coq-Club]Coq under Proof General on OSX, Benjamin Pierce
- Re: [Coq-Club]Coq under Proof General on OSX, Benjamin Werner
Benjamin Werner
- Re: [Coq-Club]Coq under Proof General on OSX, Pierre Courtieu
