coq-club - [Coq-Club] Inefficent inductive family
chronological Thread
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Inefficent inductive family
  • Date: Sun, 15 Apr 2007 10:02:45 -0400 (EDT)
In the Streams library, the inductive type Exists is defined as:
Variable P : Stream -> Prop.
Inductive Exists  ( x: Stream ) : Prop :=
  | Here : P x -> Exists x
  | Further : Exists (tl x) -> Exists x.
Suppose that one as an (opaque) theorem (forall x, P x -> Q x) and one wants to create a function f : (Exists P x) -> (Exists Q x). Such a function would necessarily be O(n) because the types of each Further constructor must be modified to change the P to a Q.
Suppose Exists had instead been defined as
Definition Exists' (x:Stream) : Prop := exists n:nat, P (Str_nth_tl n x).
The the function f : (Exists' P x) -> (Exists' Q x) could easily be defined as O(1).
Is this correct, or is there some way defining f using the orginal definition that can be done on O(1) time?
(BTW, I require the f be transpartent because I want to use the
(Exists Q x) as a witness of termination for another function. This witness must be transpartent so that computation can proceed inside Coq.)
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
