coq-club - [Coq-Club] compiler problem (with ML files)
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] compiler problem (with ML files)
  • Date: Sun, 15 Apr 2007 15:28:05 +0200
Hello,
I've downloaded the last version of Coq (8.1), unfortunately I am unable to compile some files containing the definition of additional tactics in ML
The same error remains when I tried to compile Bertot and Balaa's contribution (RecursiveDefinition) :
ocamlc -c -g -I . -I /usr/local/lib/coq8-1/kernel -I /usr/local/lib/coq8-1/lib -I /usr/local/lib/coq8-1/library -I /usr/local/lib/coq8-1/parsing -I /usr/local/lib/coq8-1/pretyping -I /usr/local/lib/coq8-1/interp -I /usr/local/lib/coq8-1/proofs -I /usr/local/lib/coq8-1/syntax -I /usr/local/lib/coq8-1/tactics -I /usr/local/lib/coq8-1/toplevel -I /usr/local/lib/coq8-1/contrib/correctness -I /usr/local/lib/coq8-1/contrib/extraction -I /usr/local/lib/coq8-1/contrib/field -I /usr/local/lib/coq8-1/contrib/fourier -I /usr/local/lib/coq8-1/contrib/graphs -I /usr/local/lib/coq8-1/contrib/interface -I /usr/local/lib/coq8-1/contrib/jprover -I /usr/local/lib/coq8-1/contrib/omega -I /usr/local/lib/coq8-1/contrib/romega -I /usr/local/lib/coq8-1/contrib/ring -I /usr/local/lib/coq8-1/contrib/xml -I `camlp4 -where` -pp "camlp4o -I . -I /usr/local/lib/coq8-1/parsing pa_extend.cmo pa_ifdef.cmo q_MLast.cmo grammar.cma -impl" term_const.ml
Error while loading "grammar.cma": file not found in path.
Preprocessor error
make: *** [term_const.cmo] Erreur 2
I am using the version 3.07 of Ocaml
Thanks in advance for your help
Houda
         Houda Anoun
    Bordeaux1-LaBRI-Signes
     phone:05 40 00 35 15
  web: www.labri.fr/perso/anoun
Electric lamps were not invented
    by improving candles
