coq-club - Re: [Coq-Club] Universe polymorphism
chronological Thread
On Sun, Apr 15, 2007 at 08:10:17AM -0700, Adam Chlipala wrote:
> You can often get around this by turning on -impredicative-set and using
> Set in place of Type.  You get the restrictions on elimination of large
> inductive types, but often you can work around them.
Alas, I fear the restrictions are crucial.
The classical example is when trying to formalize category theory in
the Aczel-Huet-Saïbi style. We define a category:
        Structure Category : Type := {
          Ob : Type;
          Hom : Ob -> Ob -> Setoid;
          (* id, compose and proofs *)
and functors and their equivalence and build a setoid on them:
        Structure Functor (C D : Category) : Setoid := ... ;
and then we find out, wow, categories and functors form a category:
        Definition CAT : Category := Build_Category Category Functor ...;
and at this point we stumble into universe inconsistency.
Impredicative sets obviously won't help, since we want to be able to
extract the Ob type from a category.
To answer Pierre Courtieu's question, my understanding of universe
polymorphism is that it means that instead of each occurrence of Type
having a fixed universe, all terms are parameterized by a
universe. Currently, if I write:
Structure T : Type := { t : Type }.
The real internal types for the terms are (using OCaml's underscore
syntax for uninstantiated variables):
      T : Type (_u + 1)
Build_T : Type _u -> T
      t : T -> Type _u
So if I now try to type the term (Build_T T), the constraint
(_u + 1 <= _u) fails, so there's no way to instantiate _u and we get
the universe inconsistency.
With universe polymorphism, my understand is that the universe
variables would get internally generalized:
      T : forall u, Type (u + 1)
Build_T : forall u, Type u -> T u
      t : forall u, T (u + 1) -> Type u
And (Build_T T) would be translated
fun u -> Build_T (u + 1) (T u) : forall u, T (u + 1)
Now the same constructions can be used in different universes,
something that's needed if we want to speak of "the category of all
categories" since we really mean "the u+1-category of all
u-categories".
This is just my hazy understanding of the situation, I have only
glanced at Harper and Pollack's paper where the idea originated.
Lauri
