- From: Benjamin Werner <benjamin.werner AT inria.fr>
- To: Lauri Alanko <la AT iki.fi>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Universe polymorphism
- Date: Wed, 18 Apr 2007 00:06:59 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:in-reply-to:references:mime-version:content-type:message-id:cc:content-transfer-encoding:from:subject:date:to:x-mailer:sender; b=KLHxSK/JzX5yvkJ/zxmYJ8ye4zL0G3R/kF2QexuJclVbzxZ+KGi6jv2Gj72x+7MUTR1wDe5NtoOHpvtzalcyCIUkumufKYaZi40QlA0I9pXHdi8CypHaN8Ckr10hhaDwmbivJ8pjt6wd5jtDVBUbuO/QCvnF/sNws8NHrSLmC5c=
Hi,
I think you are right and in these kind of examples having
universe polymorphism or not will make a big difference.
Note however that, AFAIK, universe polymorphism deals
with the way constants are treated. I think it means that
each *occurence* of a constant comes with its own set of
universe indices.
So if you have universe polymorphism you can prove surprising
statements like "A is not equal to A" (for a well-chosen constant A).
(of course you can also prove A=A, but if you try to combine the two
proofs, then you get a universe inconsistency)
Now, in the example you give, you want also each occurence
of the *inductive type* Category to come with its own set of indices.
So one should check whether this last feature does not generate
more complex constraints on the indices. I have no idea whether
this feature has been studied or implemented.
Maybye it was done for Lego ?
Cheers,
Benjamin
Le 17 avr. 07 à 22:07, Lauri Alanko a écrit :
On Sun, Apr 15, 2007 at 08:10:17AM -0700, Adam Chlipala wrote:
You can often get around this by turning on -impredicative-set and using
Set in place of Type. You get the restrictions on elimination of large
inductive types, but often you can work around them.
Alas, I fear the restrictions are crucial.
The classical example is when trying to formalize category theory in
the Aczel-Huet-Saïbi style. We define a category:
Structure Category : Type := {
Ob : Type;
Hom : Ob -> Ob -> Setoid;
(* id, compose and proofs *)
and functors and their equivalence and build a setoid on them:
Structure Functor (C D : Category) : Setoid := ... ;
and then we find out, wow, categories and functors form a category:
Definition CAT : Category := Build_Category Category Functor ...;
and at this point we stumble into universe inconsistency.
Impredicative sets obviously won't help, since we want to be able to
extract the Ob type from a category.
To answer Pierre Courtieu's question, my understanding of universe
polymorphism is that it means that instead of each occurrence of Type
having a fixed universe, all terms are parameterized by a
universe. Currently, if I write:
Structure T : Type := { t : Type }.
The real internal types for the terms are (using OCaml's underscore
syntax for uninstantiated variables):
T : Type (_u + 1)
Build_T : Type _u -> T
t : T -> Type _u
So if I now try to type the term (Build_T T), the constraint
(_u + 1 <= _u) fails, so there's no way to instantiate _u and we get
the universe inconsistency.
With universe polymorphism, my understand is that the universe
variables would get internally generalized:
T : forall u, Type (u + 1)
Build_T : forall u, Type u -> T u
t : forall u, T (u + 1) -> Type u
And (Build_T T) would be translated
fun u -> Build_T (u + 1) (T u) : forall u, T (u + 1)
Now the same constructions can be used in different universes,
something that's needed if we want to speak of "the category of all
categories" since we really mean "the u+1-category of all
u-categories".
This is just my hazy understanding of the situation, I have only
glanced at Harper and Pollack's paper where the idea originated.
Lauri
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Universe polymorphism, Lauri Alanko
- <Possible follow-ups>
Lauri Alanko
- Re: [Coq-Club] Universe polymorphism, Pierre Courtieu
Adam Chlipala
Lauri Alanko
- Re: [Coq-Club] Universe polymorphism, Benjamin Werner
Lauri Alanko
