coq-club - Re: [Coq-Club] Are proofs of inductive properties finite?
chronological Thread
  • To: Edsko de Vries <devriese AT cs.tcd.ie>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Are proofs of inductive properties finite?
  • Date: Tue, 15 May 2007 17:41:15 +0200
Le Tue, 15 May 2007 15:48:46 +0100,
Edsko de Vries
 a écrit :
> What I don't know is (a) if there can be infinite proofs of typeof,
> even though typeof is inductive,
Yes a term of an inductive type typeof is necessarily finite.
> and (b) if there cannot, how I can
> express that after having applied T_Exchange a number of times,
> another rule must have been applied.
The argument you should use is something like "if there are two
consecutive applications of the swapping rule, then there is a single
equivalent one". Once you have proved this, then you can use
contradiction by saying that after one application of swapping rule
if there is a proof of typeof t T then there is one which does not
start with a swap.
Best regards,
Pierre Courtieu
