- From: Eduardo Gimenez <Eduardo.Gimenez AT trusted-labs.fr>
- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Are proofs of inductive properties finite?
- Date: Tue, 15 May 2007 17:12:04 +0200
Hi Edsko,
Edsko de Vries a écrit :
Hi,
If I have an *inductively* defined property, such as
Inductive typeof : Env -> Expr -> AttrType -> FreeVars -> Prop := ...
does that mean that all proofs of "typeof" are finite? Or could there be
infinite proofs of "typeof", even though typeof is an inductive property?
Yes, all the elements (proofs) of an inductive type are finite objects.
What I don't know is (a) if there can be infinite proofs of typeof, even
though typeof is inductive, and (b) if there cannot, how I can express
that after having applied T_Exchange a number of times, another rule
must have been applied.
(a): There are no infinite proofs of the type typeof.
(b) Use the inductive principle on this type, which states exactly that. This correspond to the "elim" tactic. The induction principle is the constant called typeof_ind. Coq automatically derives this constant for you from the definition of the inductive predicate. You may take a look to it by typing "Print typeof_ind".
Cheers,
Eduardo Gimenez.
If there can be infinite proofs of an inductive property, can I use a
coinductive proof? (noting that I have very little experience with
coinduction, so if I'm not making sense here, please excuse me :)
Thanks very much!
Edsko
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
__________ Information NOD32 2267 (20070515) __________
Ce message a ete verifie par NOD32 Antivirus System.
http://www.nod32.com
- [Coq-Club] Are proofs of inductive properties finite?, Edsko de Vries
- Re: [Coq-Club] Are proofs of inductive properties finite?,
Edsko de Vries
- Re: [Coq-Club] Are proofs of inductive properties finite?, Benjamin Werner
- Re: [Coq-Club] Are proofs of inductive properties finite?, jean-francois . monin
- Re: [Coq-Club] Are proofs of inductive properties finite?, Eduardo Gimenez
- Re: [Coq-Club] Are proofs of inductive properties finite?, Randy Pollack
- Re: [Coq-Club] Are proofs of inductive properties finite?, Pierre Courtieu
- Re: [Coq-Club] Are proofs of inductive properties finite?, Gyesik Lee
- <Possible follow-ups>
Edsko de Vries
