coq-club - Re: [Coq-Club] Computing with recursive functions in Coq
chronological Thread
  • To: Guillaume Melquiond <guillaume.melquiond AT ens-lyon.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Computing with recursive functions in Coq
  • Date: Mon, 2 Jul 2007 05:57:16 -0400 (EDT)
On Mon, 2 Jul 2007, Guillaume Melquiond wrote:
Le lundi 02 juillet 2007 à 04:10 -0400,
roconnor AT theorem.ca
 a écrit :
Coq needs to evalutate the witness of termination into some sort of head
normal form before proceeding with one step of recursion.  Coq wants to
verify that your proof of termination isn't ``hypothetical'' by making
sure that the normal form begins with a constructor.  This means that your
proof of termination needs to be sufficently transparent and cannot have
axioms that end up at the head position of the witness of termination.
Do I understand correctly from your reply that it is impossible to write
a recursive function in Coq if you can't explicitly build an inductive
object that is deeper than the number of recursive calls?
I believe that is correct.
Or perhaps I should put False in my hypotheses so that I can build a
witness of termination on the fly without any computation?
Adding a False hypothesis won't help of course. The witness will eventually reduce down to (False_rec false_hypothesis ...) and reduce no further because false_hypothesis is a variable. Since this expression is not a consturctor, reduction of the fixpoint will no continue.
If you have any other suggestions, I would be glad to hear them. I would
really like to avoid having to extract functions into ML and then
importing back their computed results into Coq.
You can give a natural number for the number of iterations you wish to evaluate.
Making sure that the witness of termination isn't hypothetical ensures
that Coq will not go into an infinite loop when evaluating a recursive
function inside an inconsistent context (such an inconsistency could arise
from axioms or from variables or hypothesis of functions).
In theory Coq is not going into an infinite loop in your latter case.
Evalutation of the fixpoint presumably gets stuck when the head of the
witness of termination becomes an axiom of classical logic rather than a
constructor.  Then compute proceeds to put the rest of your proof into
normal form by eliminating cuts.  I'm not sure how many hours, days, or
years it will take for Coq to finish normalizing the remainder of your
proof, nor do I know how much memory will be used by the normalized proof.
(Actually, it does not take that long: the Coq process soon gets killed
by the operating system for having exhausted the whole swap space.)
The situation is kind of ironic. The witness of termination has to be
explicit so that Coq does not go into an infinite loop when the context
is inconsistent. But in my case, this restriction causes Coq to go into
a seemingly infinite loop while the context is consistent.
Needless to say, I would rather have the opposite situation: Coq would
instantly compute my function since the context is consistent, and it
would go into an infinite loop when the context is inconsistent.
Well it is nice for Coq to terminate when doing a convertability check of a term that happens to be in an inconsistent context. If not, we might have big problems.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
