- To: Guillaume Melquiond <guillaume.melquiond AT ens-lyon.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Computing with recursive functions in Coq
- Date: Mon, 16 Jul 2007 10:46:16 -0400 (EDT)
On Mon, 2 Jul 2007, Guillaume Melquiond wrote:
I'm interested in Ziv's strategy for evaluating correctly rounded
floating-point approximations of real numbers. The idea is quite simple,
you repeat your computations with increasing precision until you know
you have got the correct result (it is just a matter of looking at the
last digits of the approximation).
Images of non-trivial floating-point numbers by elementary functions are
transcendental numbers, so the functions do terminate because the digit
pattern is guaranteed to become acceptable. The proof is trivial, since
approximations cannot get closer than a certain threshold to a given
rational number, by definition of transcendental numbers.
So the correctness of this function is based on a theorem that the image of a rational point under an elementary function is almost always irrational. isIrrational would be defined something like:
Definition isIrrational x :=
forall (q:Q), exists (e:Q), 0 < e /\ (q < approximate x e - e \/
approximate x e + e < q)
where approximate x e is a returns a rational approximation of x within e.
This statement is a Pi_2 statement, so it is almost certainly provable without classical logic. Then one can proceed with Ziv's algorithm. There is only one rational number that an approximation could be too close to know how to round correctly. By apply the above theorem one can construct some e that would be a sufficent approximation. Then one can compute from this e an upper bound on the number of iterations needed.
I'm not suggesting you not use classical logic, rather I conjecture that one never needs classical logic when proving properties of algorithms and I wanted to make sure that my conjecture still holds.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] Computing with recursive functions in Coq, Guillaume Melquiond
- Re: [Coq-Club] Computing with recursive functions in Coq,
Benjamin Gregoire
- Re: [Coq-Club] Computing with recursive functions in Coq, Guillaume Melquiond
roconnor
Guillaume Melquiond
roconnor
Guillaume Melquiond
roconnor
Guillaume Melquiond
- Re: [Coq-Club] Computing with recursive functions in Coq, roconnor
Guillaume Melquiond
Bruno Barras
Guillaume Melquiond
- RE: [Coq-Club] Computing with recursive functions in Coq, Georges Gonthier
- Re: [Coq-Club] Computing with recursive functions in Coq, Benjamin Gregoire
Guillaume Melquiond
roconnor
Guillaume Melquiond
roconnor
Guillaume Melquiond
Benjamin Gregoire
