coq-club - [Coq-Club] head-normal-form and prove by reflection.
chronological Thread
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] head-normal-form and prove by reflection.
  • Date: Wed, 8 Aug 2007 07:55:26 -0400 (EDT)
I was working on a proof by reflection (for details see <http://r6research.livejournal.com/14509.html>) by creating a function that returns {True}+{complex_proposition}. Given a result of this type I wanted to extract the proof of complex_proposition (if it exists). My first attempt to do this was to write an ltac that did:
let s := eval hnf in (sum_term) in
match s with
| left _ _ => fail
| right _ p => assert (H:=p)
end.
But my problem was that hnf runs too slowly.
I managed to get something to work by using a lemma:
Lemma reflect_right :
forall A B (x:{A}+{B}), (if x then False else True) -> B.
By applying this lemma, my goal reduces to:
(if sum_term then False else True)
Now if I try ``constructor'', it still takes a long time to solve the goal, but if I instead do ``lazy beta delta iota zeta'', the the goal almost instantly transforms into True, and then constructor easily solves it. (Similarly if I try hnf at this point, it again takes a long time to transform into True).
My question is, what is hnf doing that takes so long compared to lazy evalutaiton? Also, is this a reasonable way to use reflection?
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
