- From: Benjamin Gregoire <Benjamin.Gregoire AT sophia.inria.fr>
- To: roconnor AT theorem.ca
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] head-normal-form and prove by reflection.
- Date: Mon, 20 Aug 2007 08:45:07 +0200
wrote:
Computing the head normal form of proof can be very costly.
Personally I prefer to use the following scheme:
Definition semi_dec : A -> bool:= .... .
Lemma semi_dec_correct :forall a, semi_dec a -> complex_proposition.
Proof. .... Qed.
Now you can trivially define your function. For proof by reflexion you can use the lemma
semi_dec_correct, and what you have to compute is "semi_dec a" which does not contain proof terms.
Benjamin
I was working on a proof by reflection (for details see <http://r6research.livejournal.com/14509.html>) by creating a function that returns {True}+{complex_proposition}. Given a result of this type I wanted to extract the proof of complex_proposition (if it exists). My first attempt to do this was to write an ltac that did:
let s := eval hnf in (sum_term) in
match s with
| left _ _ => fail
| right _ p => assert (H:=p)
end.
But my problem was that hnf runs too slowly.
I managed to get something to work by using a lemma:
Lemma reflect_right :
forall A B (x:{A}+{B}), (if x then False else True) -> B.
By applying this lemma, my goal reduces to:
(if sum_term then False else True)
Now if I try ``constructor'', it still takes a long time to solve the goal, but if I instead do ``lazy beta delta iota zeta'', the the goal almost instantly transforms into True, and then constructor easily solves it. (Similarly if I try hnf at this point, it again takes a long time to transform into True).
My question is, what is hnf doing that takes so long compared to lazy evalutaiton? Also, is this a reasonable way to use reflection?
- [Coq-Club] head-normal-form and prove by reflection., roconnor
- Re: [Coq-Club] head-normal-form and prove by reflection., Benjamin Gregoire
